KreatureKris
Thread starter- Joined
- Aug 4, 2009
- 4
Greetings-
I recently purchased a 1989 Stratos 201 Pro with a 89 Johnson GT200. I took her to the shop and got a quote of $4,800 to make her purr again. The mechanic wants to put in a new powerhead, VRO pump, and impeller. Obviously my concern is the idea off needing a new powerhead... and VRO pump...
The motor has a knock- and I would choose to describe it more as a subdued clack with no excessive vibration being generated. The mechanic said my #5 cylinder was only making 30 psi and proceeded to tell me my motor was shot and therefore I needed all these new parts. Now, I dont have a long relationship with this mechanic, and my knowledge with outboards of this size is premature so I need some help digesting this news.
Is this mechanic having his way with me? Seems to me he's quoted me the most expensive part and I need a reality check from anyone else besides the one who would be cashing my check.
If an exhaust valve is bad could you loose compression? Is there even an exhaust valve? If so could this be the clack? Or could the clack be the VRO and the compression issue is separate? If its not an exhaust valve issue, can the compression issue be resolved by boring the cylinders and saving the powerhead? (unless the clack is interference elsewhere related to the powerhead) Mechanic said the clack "could" be a rod bearing... but that's speculation.
Offer me theories and advice based off your experience and knowledge of this motor. Arm me with information to converse with the mechanic so I am not totally ignorant. I hope my "situation" isn't actually as bad as quoted and that I could do the work myself. I had hoped the mechanic would do better at pinpointing the exact problem rather than just decide to put in a new powerhead. So, what specifically does he know that i dont- is it all necessary?
Thanks!!
Chris
Thanks!!
Chris
