FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have a 98 gsx limited that will start and idle but as soon as I try to go faster it will only get up to about 3500 rpm with an occasional spike up to about 4260 rpm and surged. The fastest it would go was 35 mph.
both carbs need to be rebuilt most likely,, also you may try to bypass the fuel selector switch and go directly to the fuel reserve pickup on the tank,, the switches get old and restrict fuel flow .
Jeff, I know this is common problem with Seadoo, maybe others. I have a 96 GSX, and it will only run on reserve. Is there any way to clean the petcock/switch, and getting working correctly, or does it normally require replacement?
