piperdriver
Thread starter- Joined
- May 29, 2007
- 84
I have a 1990 Johnson 110. The model Num is TJ110TLCEM. I have been the owner for about 3 years. It has run perfectly. It is on a 1989 24 FT pontoon. We were cruising about 5K RPM and the motor quickly lost power. It was as if the fuel was shut off. I pulled the throttle back to idle and let it idle for a minute and picked up the throttle again. The engine accelerated normally and ran for 30-45 seconds and lost power again. If I ran it at or below 3K RPM it will run normally. Pumping the bulb did no good. I replaced the bulb anyway and it did not help. I just removed the fuel filter and it was full of oil. The VRO is still hooked up and functioning. I did notice that after the problem occured that it seemed to be smoking quite a bit more than normal. It seems that the oil is somehow backflowing in the fuel system and is now in the fuel filter. Any ideas? Thanks,
