mark_gober
Thread starter- Joined
- Jan 12, 2009
- 76
Hey everyone, need some advice from some seasoned mechanics. I've got a phillips screw that refuses to budge on a carburetor. It's a #6 screw so it's fairly large. After damaging the phillip portion trying to remove it, I decided to purchase a damaged screw remover set from sears. I've never had much luck with the type that reverse thread (similar to the grabit you see on TV), so I purchased one of the types that look like a socket set. They are supposed to grab around the outside edge of the screw and remove it. No luck. All it did was dig into the metal. It never bit into the metal. Today I was at Lowes and purchased a grabit (pro version because I figured it would be stronger). In addition, I purchased a 20 degree swivel for use with a power drill so that I could gain a more straight on angle. I was unable to go directly onto the screw without it. Unlike previous versions of this type of tool, my grabit immediately took a nice healthy bite into the screw. I thought I was finally gonna hit pay dirt and then SNAP, the grabit broke into the screw. So now I have the bottom portion of the grabit firmly imbedded into my screw and the screw is still stuck. So my questions are these....
First, anyone got any ideas on removing the broken portion from my screw. I've considered fracturing it and removing it piece by piece, but with it being hardened steel, I'm not sure how to do that. (In other words, I'd need hardened steel to break it...what would keep the new tool from breaking instead)
Second, assuming I can remove the grabit, anyone got any fool proof methods for damaged screw removal. This is the third time I've had similar problems and I've not been successful once. At this point, an expensive tool that actually worked would suit me just fine.
Mark
Mark
