Prop spinning in neutral
vandy21
Took the boat out for the test launch yesterday and when I started the engine it started reving really loud until the alarm went off and I shut it off. All off this was in neutral just sitting on the trailer. So I didnt launch it, but then today I hooked it up to the earmuffs and started it up. Same thing, prop turning in neutral. My only idea is that when I hooked up the controls I pulled the throttle closer to hook up the cables so it may be trying to rev in neutral. I'm not sure, any ideas? Also forgot to mention its a 1988 Johnson 140hp model # J140CXCC.
a70eliminator
Re: Prop spinning in neutral
When starting a boat out of the water the prop will normally pinwheel in neutral there's no torqe it just sorta freewheels along from the whip action of the lube being churned within the gearhousing, especially with the revs your dealing with, better check the throttle control linkages.
vandy21
ok, I'll check them. Yeah this isn't just turning slightly, its turning really fast!
kenmyfam
Are you sure it is actually in neutral ??
Done any other work on it recently ?? like removing the lower unit and disconnecting the shift linkage ??
vandy21
Yeah, its in neutral. I just recently hooked it up to my boat haven't run it yet. I did hook up the shift linkage myself, possible I shifted it while trying to connect the cable? If so, how will I know where neutral is?
creative993
how do you post in the forum as a new topic. I am a newbie on this site.
vandy21
there's a blue button that says "create new post" that's above the forum, but below the ads.
a70eliminator
You have to go to the top of the page and click boating forums and get out of this thread...
If you can spin the prop it's in neutral, if in gear the prop wont spin.
kenmyfam
O.K. so put it in "neutral" without the motor running and try and turn the prop in both directions a couple of rotations.
Let us know how you make out.
vandy21
with the controls in neutral, I can turn the prop by hand in both directions pretty easily.
vandy21
I only did about 4 or 5 in each direction before stopping. I can go out and try more if needed.
kenmyfam
Good enough. It should be actually in neutral when you start it then. You say you just hooked up the cables ?? for the first time ??
vandy21
Yes, I just replaced the stringers and deck and such and I bought a new engine and controls and hooked them up myself, so I probably did something wrong haha.
vandy21
any ideas? I hate to be persistent, and I am grateful for all of the advice thus far, I'm just really hoping to get out on the water soon.
vandy21
I believe I fixed it. When I put my throttle cable on, I pulled the throttle so when I was starting it, it was already spinning. Thanks a lot Ken and a70.
kenmyfam
Glad all is well. Good find !!
cougar1985
really hope you wernt starting motor on trailer without water at the launch!
vandy21
no, no, I had the boat in the water, but was still resting on the trailer.
