new to this boating thing need help
suntattoo80
ok here it is i have an 85 21 ft renken with an 92 evenrude omc140 hp v4 motor now here are the questions #1 i went out with it sun for the first time started great ran good untill i had an alarm go off in the throttle area what was that? while alarm was going off would not go above 2500 rpm about 2 min later alarm went off boat ran great for 2 more hours. #2 what is the redline on this motor? all i could get was about 4500 rpm. seem's a lil low to me but im a auto mechanic so i could be way off. #3 what is the oil to gas ratio on this the person i got it from said 50 to 1 just want to make sure im not going to damage it. ok thats all for now thank you in advance Jason....with more questions to come im sure
Texmill
Re: new to this boating thing need help
First try and find you an owners manual and service / repair guide for your motor probably on ebay. I have a '69 55hp and the oil mix is 50 to 1 which I think is pretty common. My rpms is supposed to max between 4500-5500 per the book, but my tach I bought on ebay on registers about 2500 at WOT but we're still hiting about 27mph.
tashasdaddy
sounds like you have a 140 hp SeaDrive, does the complete motor hang behind the boat? your fuel:eek:il is 50:1 87 octane: TC-W3 outboard oil. if mine i would like to see it turn 5500 rpms.
the alarms sounds like an overheat, could have been trash on the pickup, or a sticking tstat, or weak impeller. i would definately change the impeller, if the water was restricted from it, it is near shot anyway. they must have water when the motor is running.
J/E Alarms
low oil alarm is a beep every 30 seconds. beep......................beep...................
no oil alarm is a beep every 1/2 second or so.beep,beep,beep
overheat and fuel restriction alarm is a constant beep.beeeeeeeeeeeeeeeeeeeeeep
manuals http://www.outboardbooks.com/
jonesg
It went into SLOW mode due to overheating, SLOW is triggered by the heat sensors in the heads and its switched inside the powerpack ( PP is similar to distributor in a car).
Get the factory manual, its very good.
Make sure you get the service book, not owners manual and you need your model number off the engine, theres a plate usually on the leg.
Outboards are simpler than auto's but...they're stranger too.:eek:
