instrument panel diagram
jstange2
Is there a diagram that I could use to see if the wires in my instrument panel are installed correctly? Or, do I have to use the trial and error method? I have a 73 larson 18 footer.
jstange2
Re: instrument panel diagram
Thank you very much. That should help me greatly. This may be a dumb question, but where is the Nav/Anchor switch usually located? I see the terminal on switches for the wire from it, but not the actual switch.
Silvertip
The Nav/ANC (Navigation and Anchor lights) switch is on the instrument panel along side any other switches. It may just be labeled LIGHTS.
