Re: mercruiser 3.0 running issue
I have a similar problem. My 3.0 ran good for about an hour and then it started to miss just alittle. Kind of like to the tempo of rolling through the swell (just as the boat was coming down the back side of the swell/chop). Then it started to sputter choke and die. This has happened twice on the lake. The first time we ended up having to be towed in as it just would not start. The second time it would start and run for maybe 10 seconds or so before dying (just enough that we could limp it back to the boat ramp). After the first time I changed the plugs, fuel filter, coil, points, rotor and condenser.
This time I'm thinking fuel related. My plan is to replace the electric fuel pump with a mechanical. Also it does not have a water fuel seperator on it so I'm putting one of those on. I'm going to drain the tank (as I've heard that the ethanol that is being put in gas is causing this type of problem) and replace it with pure gasoline along with the additives Mercury Quickleen and Dri-Fuel. Any suggestions?
*The clogged tank vent creating a vacumm is an interesting theory!!
