1987 OMC Cobra Trim Wire Diagram
TOMG99
I Need The Wire Diagram For The 2 Solenoids Mounted On The Metal Plate On The Left Side Of The Carb On A 1987 Omc Cobra 235 Hp 5.0-I Changed Both Solenoids For Clicking And Trim Inop-after I Was All Done I Somehow Have An Extra Wire That Goes To One Of These Solenoids
TOMG99
Re: 1987 OMC Cobra Trim Wire Diagram
Thank You-does The Solenoid Have To Be Mounted To The Metal Plate To Work-does That Ground When It Is Mounted-im Wondering For Test Purposes
danond
Turn off your caps lock.
Gary H NC
I believe they do....been awhile since i worked on a Cobra trim.
I think there was a short jumper to power both solenoids.
TOMG99
Ill mount it tonight-and play with extra wire location
