Biggmack77
Thread starter- Joined
- Jun 2, 2008
- 11
Hello there,
I have a 1990 5.7 Mercruiser 350 small block with an Alpha 1 (Gen 2) outdrive. It has always been a little hard to start, but would eventually fire up. But this problem is eating away at me because it seems to be getting worse. The engine almost always fires right up at the dock when I first start it up, but after being run for a while it is extremely difficult to start again.
The engine will crank (sometimes faster than others), I get gas at the carb, I get spark as well. Usually when I am doing tests it will start very easily with only a turn of the key. But as soon as I am out on the boat with friends and its time to go home, it will crank and crank and not catch easily at all.
The starter, coil, plugs and wires were replaced last year. The carburetor (Quadrajet) was rebuilt last year, which solved some other problems, but the starting problem did not get any better. It has an electric choke which seems to work well. There is often a mist of vapor that comes out of the carb after turning the engine off, is this normal?
I believe I have a fuel problem on the engine side. I would greatly appreciate any advice.
Thank you
Thank you
