Recently bought a '73 Merc 85hp outboard...went through an ordeal to get it running and in the water, but after a weeks worth of work, she fired and runs great, except at WOT. It'll run wide open for up to 10 minutes, but after that, it wants to die out unless I ease back on the throttle, after doing which, it regains and picks up again. My thoughts are fuel starvation because the primer bulb becomes VERY soft. Brand new tank, brand new lines/primer bulb, could this be a fuel pump problem, and would holding the tank above the motor while running help determine if this is the problem? (My thoughts would be that gravity would help deliver fuel) also, as far as i can tell, there is no fuel filter except the one in the tank, and it's clean. Any help would be greatly appreciated.
