what happens when struck by lightening on boat?
wajajaja02
wondering what happens to the boat and crew when lightening strikes, in a auto ,basically nothing as it goes around the body of the car to ground, what about in a boat ?
SS MAYFLOAT
Re: what happens when struck by lightening on boat?
I would think if they are out in the elements, they would be cooked. Now if they would be inside a cabin or enclosure, I'd think it would be the about the same as in a car. I've seen lightning strike at the docks where I'm at, but no damage to any boats. I think the lightning discharges through the pipe pilings. Good Question :D
Rickairmedic
Yep pretty much exactly as that video describes . I wasnt in a boat when I got hit I was in the woods 20 some odd years ago but I still remember it like it was yesterday and am greatfull it hit a tree before me the tree suffered much worse.
Rick
tallcanadian
Rick
You had nothing to worry about, seeing your a medic...lol.
jakebrake
Would you like your boat regular or extra crispy?:p
i'm glad the guys in the you tube video survived. now, we know the answer.
dooma_Flatchy
I can tell you what happens when a boat when gets struck by lightning. It burns!! It burns Hot!! My first boat was struck by lightning in my yard and it burned up completely. The 115 merc was a big pile of aluminum goo. The trailer got so hot that the outside beams drooped over the the rims and axle. I basically raked the remains in a pile and shoveled it in the back of my truck.
kenmyfam
The bacon cooks really quickly !!!
roscoe
First off, unlike what the article says, lightning rods do not attract lightning and carry the charge to ground.
THe purpose of a lightning rod is to dissipate any negative static charge that would attract the lightning.
If it was to attract the lightning and carry the charge to ground, it would need a much larger grounding cable to withstand the current load.
I used to frequent and occasionally work at a yacht club. Sailboats and large cruisers sat there all season and few boats were every struck by lightning.
Of the few that were struck, most experienced little damage.
One I remember did blow a hole thru the hull.
Some had some "welded" hardware.
Most had damage to electronics.
Don't recall any that burned up.
Now, if you are struck, or something you are holding, that is a different story.
rjlipscomb
Roscoe, you are correct. The intent is to neutralize the charged cloud and prevent lightning strikes..
There are lighting attraction systems that are designed to attract and absorb the lightning strike.
navis
I was in Cuba a few months ago and there were massive tapered poles (maybe 2' across at the bottom) that went up easily over 100', they had 4-6 giant copper cables running down them into the ground. I'm assuming that they were actual lightning rods to absorb the bolts and keep them away from all the multi million $ catamarans. The coolest thing was that there was a meter on it that showed how many times it had been struck, can't remember what the number it read was though.
jay_merrill
I've never seen a boat hit by lightening, but I have seen a parked airplane get hit and my house was hit a couple of years ago.
The airplane was a light, single engine Piper. The entry/exit points were one of the prop blades and the rim of the nose gear tire. There was a small "melt point" on both the blade tip and the rim. In an aircraft, the practical effect of those things getting hit, is to cause both to have to be removed. Both might have been repairable - I'm not sure what the end result was. The most impressive part of the event, was that about a two foot diameter section of pavement overlay, literally exploded. We watched it all fly up in the air, from about 100 feet away!
The hit on my house scared the heck out of me! I had my then 2 year old in my arms and was just entering the front door. The strike was on the side/rear of the house. Since the strike was nearly on top of us, the sound and the flash occurred simultaneoulsy. It was deafening! It also made our hair stand - mostly body hair, but the hair on my head felt like it had a static charge too. My poor little guy was screaming - all I could do was wrap him in my arms, hustle the rest of the way into the house and keep telling him everything was OK. I think he screamed for ten minutes!
As I later discovered, the copper ground wire that comes out of the main electrical box on the house, had been knocked loose by a lawn mower. Because of this, a few things were "cooked." I did have high quality surge suppressors on most of my electronics, so I didn't lose them. On the other things, everything that had a power supply was toast. Things like battery chargers for my power tools, etc., were dead meat!
The worst part, was that I had just purchased and set up a $2,000 computer for photo editing, a few months before.I thought I had things covered, because I had a $300 UPS/battery backup between it and the wall power. Guess what - those things don't work worth a damn when the ground isn't connected (duh!). The warranty that they offer is also void in that case. One other lesson that I learned, is that you should never leave an external hard drive (backup) hooked to your computer via a USB cable. Yup, that's right, the backup fried too!
The good news is that I did not lose my monitors. Generally, you don't hook monitors to a battery backup, because they will run it down quickly. For this reason, I had them running through a high quality surge protector made by Acoustic Research - the same folks that make audio speakers. All I can say is that those things are worth their weight in gold - nothing that was running through one was damaged!
Additional good news is that I finally got all my old work off of the fried computer. While I knew that the backup was trash and most of the components in the puter (motherboard, power supply, etc. were gone, the internal hard drive actually survived. As of a couple of days ago, its been retrieved, loaded onto my current computer and backed up to an external - which now gets disconnected after every backup!
I think I've had my fair share of "fun" with lightening strikes - I'll pass on the boat version, TYVM!
thurps
Watched a doc on lightning on Discovery. They interviewed Florida ranger Roy Sullivan who had been struck seven seperate times while in his boat.
CheapboatKev
You think he would have learned when to get off the water the first time! lol:D
angus63
I know what happens when it strikes next to your vessel.
1986 I was striper fishing alone in a 19' open bow near Montauk, Long Island. I was drifting a ledge clearly marked by a large ocean bouy. Sky was dark and strikes on the horizon made me keep saying to myself "one more drift" and I'm outta here, but the fish were cooperating too well.. What happens first is your skin crawls and your hair tingles for a second or two. Then an intense blueish fist pummels you like Mike Tyson and you drop your rod overboard and fall into the bilge well. When you gain your senses your ears ring loudly and your vision is milky. You wonder what happened and then you see the ocean rapidly boiling all around the bouy about 100' from you. It then becomes obvious to you it was a lightening strike, you look for your rod but it's gone, and your only thought is getting off the water NOW!! WOT to the dock, and a quick jog to the truck. The next few hours your nerves are aided by several amber pints. The rest of your life spent leaving the fish biting at the slightest sign of a thunderstorm.
bustermin
Banned
This has nothing to do with boating, but.... I was a crane operator/mechanic for several years in South Florida. I personally have been hit by lightning several times while running the crane. when it hits while the outriggers are down it travels thru the crane and into the ground, when it hits the crane when the outriggers are up...it stays in the machine until the outriggers are put back down and you can watch the electricity go into the ground as you lower the outrigger, but if an unsuspecting person happens to walk by before the electricity gets dissipated into the ground and they get to close to the machine, well lets just say they usually don?t come to close to the machine very often after that lol. either position the crane is in, if it hits at the sheave, the lightning welds the 1-1/8" cable to the sheave. Keep in mind I am not claiming to be some kind of expert on lightning, I am just sharing personal experiences I have had.
bigskiohio
Master Chief Petty Officer
i read somwhere and it "shocked "me that lightning is 50x hotter then the sun.
Bass Man Bruce
Not trying to diss you here, but I can't imagine any way the crane can hold onto a charge????
jakebrake
you'd wonder if he remembered what the word "water" meant by the third:eek:
