2002 Mastercraft X-star
chaser7
2002 X-star, 310 HP Indmar TBI motor. 500 Hours.
Was out today. Filled ballast, pulled a rider, no problems. Sat for a while as a rain storm came through than went again. Pulled rider up, just as we were getting to speed. The engine made 3 or four popping sounds like it was missing or backfiring. Boat lost power engine light and alarm came on and I shut it down. Temp, volt and oil pressure was all good. Oil looks good and at normal level. Full tank of gas. Nothing in the engine got wet from the rain that I could see. No fluids in the bilge. Boat wouldn't start back up. Sat for 10 minutes, boat started up and idled normal. When I tried to get over 5-7 mph it would start missing and popping again and have no power. Idled to the dock. Dropped riders off, boat wouldn't start again. Let it sit for 10 minutes, it started back up and I ran it at 5-7 mph for the mile or so ride to the launch. A couple more times I tried getting going a little faster and it had no power and sputtered, missed, popped. Any ideas? Thanks.
Don S
Re: 2002 Mastercraft X-star
Water in the fuel would be my first guess. Have you checked the fuel filter? I mean check them don't just replace them. If you have a fuel/water seperating fuel filter, pour it out in a clear container and see how much water is in it.
chaser7
Don't have a fuel/water seperator filter. Only an in tank filter on this boat.
Ayuh,... Then replace what's There,+ Add a cannister filter....
Brent Raggles
My 2002 X-star did something very similar last summer. Took several guesses and we thought forever that it had something to do with the fuel. Replaced the Crank Sensor and never acted up again.
