FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
i have a 2.3L Ford in a 87 bayliner capri that i just did a compression test on. these are the results: 1: 120, 2: 120, 3: 90, 4:120. is that number 3 cylinder going to create some problems?
The engne is well used. The 90 is on the verge where it will no longer fire. It will be low on power across the range and will develop if not already have a miss even with a full tuneup. You really need to have it rebuilt. Yourself or others, she's tired. Could go into further diagnostics, but your kickin a tired mule...
When the engine is running and you open the oil fill cap do you see a whole bunch of misty oil and blow by?
With all the plugs in and when you turn it over to start, does the engine make a steady sound like da da da da da da da or does the engine sound like da da deee da da dee da da dee?
I think the pros are right and you are running a tired engine. Take er slow and fix it over the winter.
