Taking on water while on plane.
swiftshifter101
First off.. Last year I was out on the lake and my belt broke and I didn't realize it. I replaced the belt after driving it back home (across the lake) and the boat ran fine.
Then when I de-winterized my boat I noticed water in the oil. Thinking its a cracked block or something, I decided to replace the head gasket. Because I could have blown the gasket when my belt broke and not running the water pump. It truns out that I was right. After the replacement the water in the oil was gone.
So then after doing all that work to it, we put it in a well, and everything seemed fine. After taking the boat out for a spin I start noticing that there is a lot of water in the back of the boat. Thinking nothing of it and pumping it out I kept driving. But it happened again and again. Too make this worst I was driving my boat and all of a sudden the boat died, and the volts dropped on my gauge. So my question(s):
1) where could the water come from? (all the gaskets for everything are not leaking and there are no hoses leaking)
2) why is the water only entering the boat while traveling?
3) why did my boat just dead stop in the middle of the water? (Even if my alternator blew, shouldn't the batteries I have power the spark plugs till the batteries die??)
I have a 80's something Merc. I/O 140 (Iron Duke)
Please help me I'm at my wits end with this boat. :(
javajesus
Re: Taking on water while on plane.
Cast(freeze) plug popped out? Had that happen to me. Only took on water when the engine was running. Get enough water in the bilge and the engine will die. Just a thought. I'm sure someone with waaaaaay more experience will have a better answer.
danond
There is no time when a boat is full of water that one should "think nothing of it". :eek: :confused: :D
IVAZ
Master Chief Petty Officer
You need to run the engine with the cover to see if its leaking from any of the hoses very carefully. If the rubber hoses where not replaced they are now suspect (hot enough to blow a head gasket I would call all the rubber hoses gone). The core plugs might also be something to look at.
WAVENBYE2
I also agree with all of the above, freeze plug(s) or hoses would be the first to trouble shoot, if fine then bellows etc....
