mercury 70 thermostat location
kenma 1985
hi there could anyone tell me where the thermostat is located on a 1983 3cyl 2 stroke 70 hp mercury i have had a look but i cant seem to see it
Re: mercury 70 thermostat location
Most of the inlines do not have thermostats. You might look at the exploded parts diaghrams at crowleymarine.com and check it out.
jakozlow
Kenma Check your private messages. I do not think this motor has a t-stat.
Jeff
kenma 1985
thanks for that i can rule a thermostat out being the problem of it overheating then
jakozlow
It may have a poppit valve. I have same motor learning and reporting as I go. Not sure I spelled poppit correct or not.
