how do i make bigger wakes on a ski boat
sandblz
Hi i have a 1975 16 ft ski boat with a johnson 115 outboard on the back and i was wondering what i could do to make a bigger wake the big problem i have is that the boat sits low in the water already so i cant really add any more weight without having a problem with water getting in the boat so adding weight is out of the question is there any ideas that i can try thank you
Re: how do i make bigger wakes on a ski boat
i think u can put a bigger bottom end on ur motor...not sure but i think thats what one of my friends did that had the some problem. but would have to ask him
oliv83
hi , i think it's normal because your boat is not build for big wake for wakeboarding but for skiing and the big wake is not good for skiing well i think you can't have better wake if can't add any weight in your boat.
good luck
westtxguy
you can adjust your trim and it will affect your wake somewhat
