jmarine225
Thread starter- Joined
- Jul 13, 2009
- 95
Hello, I am new to this board and to boats in general. I have a 1993 Four Winns Vista and just had it serviced where i had a new upper drive installed as the old one was chewed up. After replacing it the mechanic said the engine seemed to be running a little hot so he flushed the engine and found old rubber impeller parts. He said it was still running warm after flushing it so he replaced the thermostat which he said was old and appeared to not be functioning. He said it was running fine around then. I put it in the lake, ran it and the temperature gauge was above 150 getting to about 190-200 at most. This was after running for about 30 minutes. All of a sudden we heard a water leak and steam coming from the engine hatch. We opened the hatch and found a large rubber hose (facing the rear of the boat) on the left side coming from the engine at a 90 degree angle going to the floor of the boat had cracked and was water began flowing in, causing the steam. Boat was shut down and we were towed back in, afraid to restart it. Could this cracked hose be because of the overheating or is it something different and any addtl items to check for the overheating?
