My 1986 25HP Mercury all of a sudden will not idle and run at low throttle. It will crank up fine with Full Choke & idle great, but a little rough. When I go to Half Choke or No Choke, the engine will die. It will crank again fine with Full Choke & idle again fine.
If I crank it at Full Choke and quickly push the choke into No Choke and then Full Throttle, the engine will take off and run like a champ, but if I let off the throttle to halfway or lower, the engine will die.
I have checked all fuel connections, hoses, & fittings and primer bulb stays solid. Not sure if the next step is to clean the carb since that hasn't been done in a while, but wanted to see if anyone had any additional ideas for me to try.
Thanks!
Thanks!
