Re: 1977 Mecruiser Type 1 drive, won't go into reverse
bummer, looked like for sure ya found the problem. any chance the other half of the shift shaft. the one in the bellhousing is bent too?
don't know who's parts your using, but food for thought. i R&Red my shift shaft in my bellhousing with a glm shift shaft. pos. had to file it to fit and work proper. gave me such a bad attitude, i gave up on it and called it lesson learned. bought me a oem mercuriser part and it worked proper right out of the bag...
also.
does it shift proper on the bench? this question needs to be answered one way or the other i'd think. if it don't work proper on the bench, it'll never work proper on the boat..
fwd = prop locked ccw, ratchets cw, shift shaft coupler facing stright fwd.
neu. = prop freewheels, shift shaft coupler about 15* to port. no noteable sound or feel to it..
rev.= prop loced cw, ratchets ccw, shift shaft coupler faceing about 60* to port.
did you have have lower removed from the upper? if so, when you mated the upper to lower was everything in fwd. prop locked ccw? shift shaft facing fwd. i'm thinking miss mate between the shift shaft in the lower with the part you replaced. off a spline...
if you've never replaced the shift cable going to the drive or don't know it's status. that is high suspect...
sounds like you've adj. the remote cable too. i've never adj. one. but i can tell by reading the procedure. it's something that needs to be followed exactly as described in the book or i'd guess failure in adjustment will occur...
