dkorzun21
Thread starter- Joined
- Mar 22, 2009
- 427
What to you check for maintance, Everytime you go out or every so often to make sure you boat is running good and that all the fluids are full. Im a new boat owner and dont know what to check usally I just check the oil and power steering fluid.
The reason for my questions is because sometimes when I get water in the transom area and pump it out its a little bit cloudy, Not sure if its because its dirty down there or maybe a little oil leaked after a oil change 4 months ago. There was a little dirty pan that was left in there that got wet from the machanice.
Or is somthing important that I need to check leaking???
