Thoroughbred
Thread starter- Joined
- Sep 9, 2008
- 45
Two of us actually have the exact same issue
Both are 1997 Merc's one a 200 and the other a 150.
The 200 does this:
OK, this is pissing me off and there's prolly an obvious thing to do--97 Mercury OB w/carbs starts fine, runs out to fishing place fine, turn off to drift--it even starts again once or multiple times--then, won't start; replaced fuel/water filter; replaced under cowling gas filter; blew air thru fuel vent hose to make sure it is open. New battery (different issue, but still....).
Happened at beginning of last season, but I thought I was out of gas and added/filled and it worked rest of season no probs.
This year--got stuck 2 weeks ago, got a tow. Started as soon as I reached dock.
Today, started, ran fine, started again; drifted for a half hour, wouldn't start. Ball hard, could smell gas even, waited, tried, waited, tried, etc.
Called for a tow; kept trying to start off and on; not sure which try, but, started went home, turned off, started again at dock.
Motor not sputtering, runs normal when it starts.
Any theories? What should I do next? Replace fuel pump? The starter cranks, so I'm guessing it's not electric, but hey? Replace plugs?
......and the 150 did this:
I have the same problem, 1997 Merc 150 offshore. Did it to me last week when at Cole's Point. Ran about a mile to fish. Drifted for about an hour then it wouldn't start. I sat for another hour cranks and won't start even with spray (starting fluid). Sat another hour remove plugs, cleaned and sprayed each. Also opened gas tank in case of vacuum and then tried it and it started. Happened to me once last year too but that is it.
For what it's worth I had new plugs, fresh NON-eth fuel with Startron.
Would love to figure this thing out because I feel uneasy turning it off.
Any and all help you can give us would be greatly appreciated!!!!
The 200 does this:
