correct idle speed
richardson61
i have a 93 Searay with a 4.3 L i've heard correct idle speed should be around 600 rpm's. anything under 900 mine will die out idles best around 1000 or 1100 but afraid this is do high for shifting into gear. have done completed tune up, rebuilt carb, and adjusted timing best i could at 1000 rpm's
Haut Medoc
Re: correct idle speed
You missed something, 900 is too high, you will destroy your drive if you keep running it like that.....
Check all of the ignition stuff first, but my guess is the carb.....;)
richardson61
i've rebuilt carb, is only one adjustment screw and adjusting that seems to make little or no difference. we are having other running problems but have come back to the idle since trying to set timing properly. but the high idle has been a problem for years
richardson61
to correct other operating problems have replaced plugs, wires, cap, rotor, ignition module, coil, and pick up sensor
searay3
You don't give specific engine id or carb. There has to be at least an idle speed adjustment and mixture adjustments, usually two. What kind of carb and your timing is off if set at 1000 rpm.
Gary H NC
Sounds like he has the Merc Carb with the single idle mixture screw in the front..:confused:
How are you setting the idle? In the water or on the muffs?
richardson61
sorry, its a 4.3 L with a 2bl Merc carb with the one idle mixture screw in front. have adjusted the idle while in water. even tried Seloc instructions to adjust idle mixture screw with boat idling in gear, had preset per instructions at 1 1/2 turn out, turn additional 2 turns out with no effect
richardson61
i even thought my in dash tach was reading wrong so hooked up external tach and got same results
searay3
to see if your carb rebuild took, turn the mixture screw in, gently. It should start to die. If it has no effect the carb still has issues. If it does change, remove the throttle cable and turn the idle speed screw out while applying pressure to close the throttle plates with your hand. Could be there is something binding not allowing the plates to close properly.
richardson61
should it die if turned to the stop? and if it doesn't what carb issue should i be looking for? Should the plates close completly?
gadget73
See if the carb mounting bolts/nuts are loose. Had this happen on one of my 4bbls and it was a loose bolt causing a vacuum leak.
searay3
Check for a tight mount as mentioned. If you can spray carb cleaner around the base of the carb and the rpms change, you have a leak. If all is tight and the mixture screw has no effect, then you still have blocked passages in the carb. Take it completely apart and soak it in carb cleaner. the spray stuff ain't good enough. Dunk it overnight in the carb solution you get at NAPA, in a bucket, blow all passages clear with compressed air and reassemble. It is also possible the carb body has deteriorated and a rebuild may not work. It's been said its a 50 50 crap shoot on a rebuild...
richardson61
k, will check attaching bolts, and mixture screw. didn't soak on first rebuild just use spray and air will try soaking if all else fails. may or may not be related but did rebuilt cause was bogging down after running for awhile could this all be related?
Ayuh,... What was the general condition of the carb when you opened it up,..??
It's no doubt All fuel system related,...
I'm not sure or not as to whether it's Just the carb though...
richardson61
the accel pump plunger was chewed up so bits of rubber in bowl, not a lot of varnish or other debris though. Are you thinking it could be fuel pump Bond-o ?
i've rebuilt carb, Are you thinking it could be fuel pump Bond-o ?
Nope,... I'm thinking you Missed some of the Idle Circuit passages....
When you screw the mixture screw in to Lightly seat it,... The motor should Stall...
richardson61
How do you tell where the idle circuit passages are? or just soak and clean the living dickens out of it again?
krisnowicki
If the plunger was chewed... maybe pieces of that rubber are inside it. Go through the carb agian and make sure you timing is on and I bet you are all set...
richardson61
thats my plan for this weekend, only problem with getting timing set correctly is getting it idled down to 600 rpm's without stalling
richardson61
rebuilt carb again soaking overnight, idle a little better. decided to check plugs and compression. top burnt off 4 of the six plugs, 0 compression on 1, 3, and 4 140 on 2 150 non 5 and 6. anyone have any ideas what could cause this and where to start looking?
