I took my boat out for the first time after completing the project this weekend. The boat is a 15 ft tri-hull open bow and I put a 1960 Johnson SS 40 Hp RDSL-22 engine on it. The boat ran good except it does'nt seem to go fast enough. Seems like it needs more throttle or something but the throttle is opening all the way.
Also,There are some tilt adjustments on the motor, would changing the position help? Not sure what to set them on. Also, is there a standard starting point for the lean/rich adjustments on the low speed and high speed side? Seems like they need adjusting too and not sure how to do it.
One more point: the fuel in the tank i was told by previous owner was a 50:1 mix, I ran out of gas in the middle of the lake and put some 25:1 mix in it and it did'nt seem to run right afterwards.
Any help and info would be greatly appreciated.
Thank you!
Thank you!
