1997 4.3L Mercruiser (carbureted) installed in a 19? Bryant. Freshwater only.
Replaced engine this spring due to damage to the starter mounting flange on block caused by hydrolock. Certified local Merc dealer installed a new engine which now has 20 hours on it and, up to this point, has run great. Last ran the boat July 4, loaded on the trailer and brought it home. That night torrential rains hit the area and the boat was uncovered. The following Wednesday I launched the boat, turned the key and the engine turned less than ? revolution and stopped. Fast forward to last night. Removed all plugs. #2 cylinder was filled with water. Checked oil ? oil was not milky but the dipstick indicated a very high level. Opened oil drain valve and of course, the first fluid to drain, and lots of it, was water. Cranked the engine and water from ALL cylinders spewed out. Removed both manifolds and tested (with risers attached) by simply attacing a hose to the water inlet No water breeched the exhaust ports and, there was no sign of rust or water in the manifolds. Someone suggested that water is draining into the carb (see rain above). Inspecting the plastic carb cover I noticed a crack, approx 4? where it appears that someone over tightened the cover. Opening the carb fully reveals some rust in the intake. Help and advise is greatly appreciated
