FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
It depends on where the leak is.
If its coming in through the driveshaft seals, or the shift shaft seals, or the drain and vent screws, its pretty easy. If its leaking at the prop shaft, its gonna be a chore.
You can pressure test the lower unit in a tub of water, using 2 or 4 pounds of air pressure, to locate the bad seal.
