Total combined weight
KP ENT
I have a 1986 Thundercraft/ magnum fiberglass boat with a 185 hp. merc inboard, and a shorelander trailer. Can anyone tell me what the total combined weight would be or even close? thanks
rbh
Re: Total combined weight
alittle trick Ihave done in the past is put my garbage in the boat, go to the dump, they weight you in and weight you out. You just look at the reciept to find the weight on the trailer tires
then ball park your tongue weight.(if you can pick it up by hand it is? or put the leg on a scale when you take it off the ball)
some trailers will give you the build weight as well as the gvw
rob
Silvertip
Look up the model specs for your trailer on the shorelander web site. This list trailer weights.
