505callyourball
Thread starter- Joined
- Jul 7, 2009
- 47
Hello everyone! I am new to iboats and to I/O's. I'm pretty familiar with GM engines but not in this application (if there are internal differences from the street version). I have an '01 Caravelle with the 4.3GL carb engine. There is start-up smoke so I assume that it needs valve seals. When I do this, will these be non adjustable rockers or the regular type? While I've got the plugs out I plan to replace them. Can I use street plugs for an '01 4.3 vehicle or does it have to be a marine plug? (few boat shops in my area) There is also a hole in the flex hose when looking at up at the bottom of the Alpha 1. There seems to be an upper and lower hose, this would be the lower. tic tac size hole. What is that hose for and is the hole a big problem? Thanks in advance and I'll keep it shorter next time!
