Replacing manifolds/Risers on 5.0L
SirFrank
I'm about replace manifolds and risers on a 1995 mercruiser 5.0L in a kinda tight place, I know I won't have any troubles getting the bolts out, as these were new last year with a block change, but this is my 1st attempt, so I was looking for some helpful clue's ... reading this forum gave me alot of info and tips... but 1 thing comes to mind when taking off the elbows, should I heat up the engine for a bit 1st or will the elbows come off the belows easy enough, or does it make a difference?
Another question, if the elbow gaskets come pre-sticky, is sealer needed in adition? my guess is no, but some expert advise is appreciated.
I also found alot of different answers when it comes to torqing... some say 22ft/lbs for the manifolds.. some 30, or 33..
any ifno is greatly appreciated.
Frank
95' 2050 Bayliner Anniversary Edition
5.0L Mercruiser / Alpha I Gen II
mkast
Re: Replacing manifolds/Risers on 5.0L
Using the correct Mercruiser maintenance manual will answer your questions without relying on some one's memory.
SirFrank
hmm... if I had one, I surely wouldn't be asking... but anyways, I did call around for one, and to no avail... i am doing this tomorrow.
Zackman
Here is a link to Mercruiser's Service Bulletin 99-10, Exhaust Manifolds, Risers and Exhaust Elbows. http://www.boatfix.com/merc/Bullet/99/99_10.pdf​
Read cafefully, make sure you are using the right manifold to riser(elbow) gaskets. The torque spec is there for the risers. The manifold to head torque spec is 25 ft*lb. No sealant needed on either gasket surface. Use only Merc gaskets. Be sure all gasket surfaces are clean and level. Spec for risers is in the service bulletin.​
SirFrank
very nice, thankyou a bunch for this.
Ayuh,... Clean gasket Surfaces are what's Truely Important....
Ayuh,... Level as in FLAT.... Straight-edge Flat....
