Hydraulic leak from trim pump
rocket1968
I thought it was the line, but after futher inspection, the trim pump is leaking right next to were the hydraulic line connects at the bottom. THis is a a 1976 165 i6 boat with a square pump on the drivers side of the engine.
Is there a rebuild kit for these? or a schematic? ziggy?
Bt Doctur
Re: Hydraulic leak from trim pump
If I looked I`m sure I have a valve body but it`s connected to the base of the pump body with "O" rings. I think 2 bolts hold the valve body to the pump,remove them and the body comes off and there should be 2 "O" rings there .
Bt Doctur
