90 hp optimax lower unit question
grg
I have an 06 90 hp optimax. I am thinking I need to change or atleast check the lower unit oil. I do not know if the oil has ever been changed. Do I need to just check the oil or change it? If i just ad to the oil can use just any lower unit oil or do i need to only use the quick silver?
Thanks
GRG
BikerBen
Re: 90 hp optimax lower unit question
You should change it. Use any good quality marine gear oil. Then you'll know what you have in there and when it was last changed. I change mine twice a year...at the beginning of the season and at the end. It's easy enough to do and a lot less expensive than replacing the lower unit.
blazer81.6
Good idea to change before winter months at least. Exactly, a lot cheaper for 10.00 for oil rather than 1000 for a lower unit.
