i have an old hourston 17'. the motor mount bolts are tightened enough that the washers noticeably compress the fiberglass liner against the transom, I wouldn't say to the point that it's cutting through the fiberglass but to the point that the bolts are denting the fiberglass. Is this normal or should I be undoing the bolts and putting a metal plate between the bolts and the transom (which I do have available) The transom seems very strong, no cracks or flex except around the engine when I push and pull on it and only a tiny bit. The engine is a 1995 Mercury 60 hp. Approx. weight is 220lbs. thanks, sean
