tkmichael11
Thread starter- Joined
- Jul 30, 2008
- 41
Im still trying to figure out my '80 228 merc problems. I have some problems that hopefully this board can help me with. The issue is stalling after running well for a few minutes then eventually failing to start all together. A few things are perplexing me. I checked the vacuum and its steady at 15 and that is with the timing at 8 BTDC which is according to the manual. If I adjust the timing to get the vacuum to 20 (which is recommended) the timing marks are way off. The air/fuel mixture is set to 2 1/2 turns on each side of the Rochester Qjet. Dwell is 28, points are set at 17, spark plug gap is .035. Should I set the timing to proper vacuum and forget the timing marks? Also, I was looking at the service manual and for my motor, it shows the number 1 wire attaching to the dist. cap directly across from the alignment notch. However, I have the number 1 attached directly beside the notch. I have put #1 on TDC and checked the position of the rotor and it points to where I have the wire. Could this be an issue? I'd love to get this running correctly before the end of summer.
