Price to change a lower shift cable?
rainman1999
I,m not confident enough to pull my drive off yet and was wondering what a fair price is to change the shift cable in a alpha 1 gen. 2 mercruiser. 2 hours labor plus parts?
JustJason
Re: Price to change a lower shift cable?
2 hours??..... Hmmm double that and add an hour for starters.... i've pounded them out in under 4 hours in rinky dinky 4 banger boats.... and i've had ones that have taken all dang day..... plus parts of course.
wca_tim
it's a pita... I just did it last night and if I had had the time and it was convenient I would have gladly paid someone 4 hours labor to do it!
of course it didn't help that the outdrive bell housing came out in pieces...
rainman1999
I meant just the lower shift cable
45Auto
2 hours plus parts is a reasonable estimate for a lower shift cable replacement on a clean, well maintained boat. There's always the possibility of corroded and/or stripped fasteners that could cause additional problems.
mkast
If this maintenance is being performed on a 1987 hull, it might take a little longer than normal. Saltwater use? Be prepared to see the usual, universal joints, bellows and gimble bearing.
nailem
in the spring i got prices for lower shift cable, all bellows and gimbal bearing $550 including parts. i eneded up doing it myself for $180 after i had to cut one of the hing pins out. i figure if the shop had to do that add another $100. it took me (first time doing it) about 5-6hrs
