PeteyDaMan
Thread starter- Joined
- Jun 30, 2009
- 51
I have an 83 SeaRay SRV195 (V hull, 19.5ft) with a Mercruiser 260 (5.7).
I just rebuilt the top end with new valves, manifolds, risers and gaskets and want to figure out if I have been running the right prop or not. I've been using a 15x15 aluminum 3 blade for the past 5 years but I'm starting to suspect that I shoud be running a 17. At WOT I'm typically up around 4800 and I'd like to bring that down to around 4200 as the motor is a little on the old side.
I'd like to stay away from stainless.
The boat is used mostly for tubing and needs a good hole shot.
