FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Hey all, I need some help. I have a 1960 40hp evinrude and when i have it at full throttle it seems like it is only running about 1/3 speed or power. Any thoughts? Thanks for your help!
Sounds like you're running on one cylinder. Do a spark test with a good tester. Or remove the plug wires one by one when it is running. If running on only 1 cylinder then 1 wire will do nothing and the other will kill the engine.
Im Having the same problem with my 1996 48 Johnson. So if u pull off one plug and nothing happens and then u put it back on and then pull the second plug and it dies that means its running on one cylinder?
