KTOWNCABBY
Thread starter- Joined
- May 31, 2009
- 8
Hi Folks; Was Out Last Night Ran About 20 Miles Revving Around 3500-3800, Boat Worked Fine. Stopped For Dinner About 2 Hours And On Way Back After Bout Half An Hour Of Running Around 3700 Rpm Boat Started To Lag. Dropped The Rpm's Down To 3500 It Seemed To Run Ok But Then Dropped Rpms And Stalled. After That The Boat Would Only Keep Running At Around 2000 Rpm. The Thing Stalled About 3 Times But Would Start Right Back Up. Temperature Was About 130 Degrees. Oil Pressure Seemed High To Me Right Before This All Happened; Just Under 80 Psi. After First Stall It Was 60 Psi Were It Usually Is While Operating. The Oil Level Was Fine When I Checked It. This Boat Sat For 18 Months And I Purchased It A Month Ago. Have Put 3/4 Of A Tank Of Gas Through It Since Purchase. 1/4 Tank Of Fuel When This Started Happening. I CHANGED THE FUEL FILTER AS THE MECHANIC AT MY MARINA SAYS THERE COULD BE WATER IN THE TANK FROM IT SITTING FOR 18 MONTHS. WOULD THIS CAUSE THE SYMPTOMS I'M DESCRIBING. WOULD ANYTHING ELSE OTHER THAN BAD GAS CAUSE THIS PROBLEM? ALSO WONDERING HOW HIGH THIS ENGINE WILL REV AND WHAT IS A SAFE RPM RANGE TO OPERATE IT AT. I HAVE BEEB CAUTIOUS NOT REVVING IT AT OVER 3800 RPM JUST TO GET IT ON PLANE. Any Opinions Appreciated
Ktown Cabby
Ktown Cabby
