`99 5.7 /ser# OL 090717
Bt Doctur
Would anyone have the correct part number for the oil pressure switch for the fuel pump.
Thought is was 87-864252 .That is the wrong unit, but if someone needs that one I have it.
cooter2506
Re: `99 5.7 /ser# OL 090717
87-864252A01 Try that one. The one you got was for a 5.7 serial #0M331444 & Up
Bt Doctur
That # comes back with a picture for the audio warning system.
The one i need is the pressure switch for the fuel pump .nobody put pictures anymore.Has 2 blade terminals
cooter2506
I know they changed the switch from the terminal type to the plug type tht is shown in the link I sent
Bt Doctur
That might do it, Somebodys always changing something .What ever happened to keeping it simple.The old one came with blade terminals, the new one now needs a harness.Another point for a failure.
Thanks for looking.
cooter2506
No problem im here to help just like you. I change the old style to the new style on y old 5.0. Thats how I found out last year about the change.
Bt Doctur
For anyone else following this post on the fuel pump pressure switch ,if you have the one with 2 blade terminals it is NLA.This kit updates to the new style and includes a wiring harness to plug into your existing wiring connectors.
Merc # 87-864252A01
