Re: What tools on board for an I/O ??
I keep a basic tool set consisting of standard sockets ( regular and deep), standard wrench set, screwdrivers, crescent wrenches, hammer, wire strippers and crimps, wire connectors,duct tape ( don't laugh, you should have it too) needle nose pliers, regular pliers, spark plug socket, misc extensions. I'm sure I'm forgetting a few things. If you have a points ignition system, a set of points is a good idea as well as a new fuel filter, starting fluid ( works in a pinch, but I really don't like to use it). Basically think of anything that can go wrong on the lake that can be fixed on the lake and have the proper tools. Remember, you can't fix everything out there, and some situations will require a tow.
