speedoflite2
Thread starter- Joined
- May 25, 2009
- 56
My dad went to the lake with his boat today that he just bought. We had it running on muffs with no problems, and this afternoon he went to the lake to try it out. Put it in the water and it fired right up pured great he said. Then still in neutral it just quit as if you turned the key off. (This boat has no key just push button start) Didnt cough spit or sputter. He cranked it over and over but would not fire at all. Brought it home and I went over things with him. Has spark out of both plugs, but one is weaker than the other. Turns over great , fuel primes up and hold pressure. Glass bulb fills up and fuel filter is clean. There is fuel pressure all the way to the carb with no restrictions. I pulled the gas line off the carb and pump primer bulb up and fuel shot thru. Did not try spraying and gas oil mix in the carb as I didnt have a bottle to spray in there. What am i missing here???? If the carb would be gunked up would it just shut down??? It would have spit and sputtered correct?? Any help would be much appreciated. Thanks in advance fellow captains of the sea.
