I have a volvo penta AQ225E with a 275 outdrive. The motor is running hot on muffs and when it is in the water it will run cool if the throttle is 1/2 or UNDER if it is over 1/2 it overheats. The impeller is new, just installed a new water pump as well. Just seems like im not getting much water out of the outlet hoses and a good amount out of the exhaust flapper. Used to be reverse untill I redid the lower unit seals. Did I maybe block a water jacket or something? This one has me scratching my head. Because it didnt start doing this untill I replaced the seals. Then I was like oh my water pump went so I slapped a new one on there and still nothing. I checked the impeller as well and it looks good. Any thoughts?
Matt
Matt
