Sunsearcher
Thread starter- Joined
- Jun 10, 2009
- 6
Hi
I was wondering if any of you knowledgeable people could help me out on this one, I have a 1980 Glastron 266 (27 foot) twin fitted with a pair of Mercruiser 470's driving pre alpha stern drives (1.81). The boat goes very well except, at idle the boat is a pain in the marina as it the slowest it will go at idle is 8 - 10 knts, top speed is good, at 48 kts however the engines are only running at 3800 rpm WOT (speeds via gps). I have checked the props fitted and they are part number 48-36008A1 25P (I guess the 25P is the pitch). I have contacted Glastron to see what props should be fitted and they say all their records pre 1990 were lost, therefore I have to start from stage 1.
I have done a lot of research and have found that boats with similar size / weight / displacement / engines run either 15 x 21C or 15.5 x 19C. I know doing it this way is a little less than scientific, but it seems like a good place to start from
Can anyone advise the following
Is there a real difference in 15 x 21C and 15.5 x 19C
Given my performance with 25P should I go for the 21's or the 19's
Any help and advice would be appreciated
Many thanks
John
Many thanks
John
