Hi,This is my first post here and have gotten so much help here previously I figured I'd join in the fun.I just purchased a 1966 Mfg and the motor is a 1966 Evinrude starflite 100-s.It started right up.After a tune up and good cleaning it runs great.Over 105 psi on all cylinders,impeller is in good shape,stat was removed and tested,I'm getting spray out of the exhaust but it seems to me that it is still getting way too hot.I can't touch the block or the head for more then a second.Internal combustion means heat,I know this, but how hot should it get?Am I just being overcautious?What temperature should it be?I'm also concerned that the overheat alarm isn't functioning or is it just the dash light,can I test it.Thank you for any help or advice.
Btw I'm running it in a bucket with fresh water running into the bucket and the pump inspection plate removed if that helps.
