fastandfurious
- Jun 16, 2009
- 9
Hi
i'm just in the process of fitting a new water pump impeller.I have removed all the casing bolt and finally freed the lower prop casing,but i can only get the casing to drop about 2cm.I can see the water pump through the gap and see the water pump bolts and even loosen them ,but i can't get the casing any lower.What is holding it up............?
I can also see a water pipe through the gap and that is free of the water pump.
thanks in advance for any help.
