Thermostat Question 50 HP force
cbercaw
I am testing a 130 degree thermostat for my 1988 50 HP force. The engine has an overheating problem. The thermostat opens smoothly at 140 degrees. Do I have a faulty thermostat? Is 10 degrees enough to make a difference? On another note, is there a certain way to orient the thermostat that I might not be aware of? I have the rubber gasket side toward the cylinder head because that is how i found it...the engine overheats when throttled up...it is fine in 1st gear or neutral.
john from md
Re: Thermostat Question 50 HP force
The pointed part of the thermostat goes into the engine. When was the last time you changed the impeller? Are you sure the key is in the shaft? Is it used in salt water? Was the lower impeller pump housing corroded?
Get back,
John
cbercaw
Hey John, I changed the water pump/impellar April, 2008. I use it in the very upper chessapeake and its rivers so i guess it is exposed to brackish water. I am going to drop the lower unit now and take a peak.. I will post more info later....Thanks for the reponse...Chris
cbercaw
but I should mention that I try to flush/run it with freshwater when I get home every time....
john from md
When you remove the upper housing, impeller and wear plate, you will be able to look at the lower housing. The walls of this housing must be intact or the water will leak back to the inlet side of the pump. If you can, send photos to johnandnanc182@yahoo.com if you want me to give you an opinion.
John
cbercaw
John, you have mail.
steven4141
Being one for overkill I always change wear plate and housing when I change the impeller, just to be sure. If it's not the wear plate or impeller, check for plugged water passages, if not that, check your compression, could be a blown head gasket
john from md
Cbercaw,
I have not received any mail from you. Try again.
John
cbercaw
Hi, Steven, I replaced the head gasket a couple months ago... but the cooling jacket leaks a little at the bottom.....
