shifting to fwd or rev
grandpacrotchrocket
On my ocean pro 115 with the shift cable disconnected and engine running should I be able to shift by hand from under the engine cowl? I do I need a bar or screwdriver to lean against the lever to make it go into gear. Can"t get it to go by hand but can use a large screwdriver for leverage to get fwd or rev. Could this be a problem in the lower unit? Has not been apart since I have owned boat. thanks
tashasdaddy
Re: shifting to fwd or rev
how long have you qwned the boat? being in Tampa, if the water pump and tstats have not been service in 2 years you are over due. you can check then, could be rust on the shaft.
grandpacrotchrocket
are you talking rust on the shift rod? Or on the shaft? If the shaft I don"t see what that has to do with shifting. I have had the boat going on a year now. New water pump and new lube service the week I picked up the boat. If my shifting problem is in lower unit I will replace water pump while I have it down. But I still don"t understand what that has to do with the shifting. thanks
dingbat
I can shift my 200 by hand, no problem.
TD is pretty much on track. No rust, SS shift shaft. Problems with build-up on the seal where the shaft enters the housing are common.
