FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Re: 68 johnson 40hp super seahorse/ think I made a mistake
good thought what is that anyway? I did not see any other way to drain the lower unit it has the fill up top and the only screw at the bottom was that dang phillips head. I also notice this motor does not have a kill switch on it has a toggle switch with a red and black wire comming out of it but have no Idea were it goes looks like they had it to the starter. but there is no silonied in the thing
I did I'll look again but I don't see one on either side going to lay it on its side and I think I can get it in was able to silde it up with my dental tools but drops back down since its sitting on the rack. does it just slide behind that what have you or is there a hole Im looking for to slide it through also did a pilimanary cop check both cylinders are at 110psi what was factory 150?
thanks
