Well, it's been a while, but I think I am finally ready to get my old '77 Glastron back together.
I rebuilt the Merc 888 (Ford 302), and am about ready to drop it back in. I have a few questions, however. They are:
1) While the engine is out, and the drive is off, are there any other maintenance tasks I should accomplish while access is good to the transom? It's an old boat, and it seems like the steering was a little 'loose'. How should I go about tackling this issue? Also, the gimbal bearing spins smoothly without any hitches and appears rust free. Should I replace this anyway? Hate to spend the money if it doesn't need it.
2) I was planning on installing the engine minus the heads, exhaust manifolds, intake, etc. so I didn't have all that weight on the mounts, making it a little easier to align. Anyone see any problems with this or have another suggestion?
3) The reason for the rebuild was water in the oil and rod knock. While dis-assembling the old motor, the machinist didn't find any cracks in any of the castings (block, heads). During disassembly, I couldn't find any telltale signs of water getting by any gaskets (intake, heads, water pump, etc). So that leaves the exhuast manifolds and shutters. I haven't got the y-pipe out yet, but I am doing that tonight or tomorrow night to check the shutters. That leaves the manifolds and I'm not quite sure how to go about inspecting them for cracks. But so far, I can't see where the water came from.
4) As noted in another post, I belive I was having trim issues before the rebuild. What's the test for weak trim pumps and cylinders.
Thanks to all, this forum has been extremely helpful (with the occasionally not very helpful post :>)
