It is being used for a vacuum port on a '57 Johnson. It is a Watts #17090192. Thanks.
B ba_50 Chief Petty Officer Thread starter Joined Apr 4, 2001 Messages 637 Jun 5, 2009 #1 It is being used for a vacuum port on a '57 Johnson. It is a Watts #17090192. Thanks.
J jonesg Admiral Joined Feb 22, 2008 Messages 7,198 Jun 5, 2009 #2 Re: What drill and tap size for 1/4x 1/8" barb fitting take the barb fitting to the hardware store and find the nut that threads onto the threaded part perfectly, thats your thread size, then just buy the drill/tap pair to suit.
E ezeke Supreme Mariner Joined Sep 19, 2003 Messages 12,532 Jun 5, 2009 #3 Re: What drill and tap size for 1/4x 1/8" barb fitting http://shop.hoseandfittings.com/techinfo/display.html?techinfo_id=29 225-4-2 1⁄4" ID Barb X 1⁄8" MIP A-192B 17090192 048643163676 1 5 60 2.59
C Chris1956 Honorary Supreme Mariner Joined Mar 25, 2004 Messages 29,342 Jun 5, 2009 #4 Re: What drill and tap size for 1/4x 1/8" barb fitting I believe those fittings are NPT which is a tapered thread. You will need an NPT Tap.
