I bought this 94 Bayliner w/Force in May 2007. No problems with trim in 2007 & 2008 seasons. Kids were in boat during winter and left key on, which caused the battery to die. I recharged battery and engine starts fine. But I didn't realize until last week that the motor is stuck in the up position. When I press the tilt/trim button, I hear only a click. Does this have anything to do with the previous charge problem? Assuming it doesn't, and after reading some message posted on this forum, I ordered a two new relays (only the half with the teeth) thinking this might do the trick. It did not. Could it be a lack of oil in tilt/trim reservoir? Would lack of oil cause the tilt/trim to "click" only? I'm not sure how to check the level, or even if this is the problem. I'm not terribly mechanical, but I have a pretty decent level of common sense to figure things out. I'm trying to avoid dropping hundreds into resolving this problem if at all possible. Thanks!
John
John
